Brake Rotor
danotech
I am in need of a front brake rotor for a 2014 RT. Please let me know if you have a spare or a source for a new one.
Dan
Sent from my SM-G930T using Tapatalk
BRAKE ROTOR
Sponsor on here quick service and good prices
You could have issues if you replace one ROTOR , I would recommend TWO from BAJARON, they will help you stop better and they well last longer and I'm quite sure TWO of His are LESS than one OEM from BRP.........Mike :thumbup:
Try this..
BajaRon first...cheapcycleparts.com (oem rotors) ebay may have them then there is brp :gaah:
I believe it is warped. I'm getting vibration in that wheel during braking. Suggestions?
Just go to home page and click on his website and you will find what your looking for and a lot more goodies.
I would check the rotor for warpage before replacing it. Worn A-Arm bushings can give you the same effect as a warped rotor.
If I did have to replace one what is your cost?
I only carry the EBC replacement rotors. It would be very bad to put just one on the front as the EBC rotors stop quite a bit better than the OEM rotors. You do not want uneven stopping power on the front wheels. So you'd need to purchase 2. You might look into a used OEM rotor. Though you may run the risk of getting someone else's problem.
A new OEM rotor will cost you about $250.00. The EBC rotors are $104.00 each delivered.
Material Transfer
Another possibility is material transfer from the brake pads. If the warp test with a dial indicator shows only a few thousands deflection M/T is a possibility, A good sanding and cleaning will do the trick.
Kaos
