That break pedal will not work on a 14, I understand what you are saying, even with my small feet I find the break pedal to not feel quite right, as if my legs are too long and that certainly is not the issue, lol. The floor boards are designed to break away you really slam the pedal down so any change to the pedal could interfere with this, FYI
The ULTIMATE solution to your problem is the ISCI hand brake conversion. Braking will no longer be an issue. The ISCI unit is superb in all aspects.
:agree: I have the ISCI hand brake and it is the best decision I made. Really makes my ride more enjoyable. A bonus is that when you start to grip the hand brake, the foot pedal starts to lower on its own which makes it easier to get your foot on it in the event you need to hit both at the same time.
Quality product. It is a pricey mod but, for me, it was worth every penny!
Good luck!
I wonder if they changed the design or what's up with my bike. I saved mine off of my 2011 but it is too large and prevents the pedal from going down far enough in a panic stop.. ask me how I know, lol. I will try it again but don't want to find out when I really need it again.
My memory is sometimes a bit foggy but I seem to remember from another thread the minimum thickness of the spacer under the bigger pedal is real important. Like you found out it's only a problem in an emergency.
