Brake pedal position solved:
I mentioned (another thread) that the brake lever is too high for my wife's liking. Her legs are short, so UFit position A is where it needs to be. I was ready to cut and re-weld the brake rod, but another option struck me. The brake rod has a hole in each end for mounting. There is enough room left to drill another hole 1/2" inboard of the OEM hole. This can be done on each end for maximum change. I did it on one end only and the pedal moved to a much better position. If she wants more, I can do the other side, too. It takes 2 minutes to remove the rod, 5 minutes to drill/file the 5/16" hole, 5 minutes to slightly trim at the point of assembly if needed, and 2 minutes to re-install. It was very easy and, in my opinion, there is enough steel around my drilled hole to be as strong as the OEM hole. One poor pic attached.
There you go...!!
several have asked about this so you have given them a solution...great job...:2thumbs:
