Brake pads squealing in reverse
Hutch
Hi all, I have a 2011 RTS that has had the brake pads replaced by the person I purchased it from
they are aftermarket pads which are noisy at times when stopping
im OK with this but my bigger problem is that they appear to rub in reverse and emit a loud squeal and the only way to lessen it is to ride the brakes when reversing
my question is, is this common or should I have it looked at
cheers
It's common. My 08 GS does the same thing. You can try keeping the brakes cleaned to help reduce it some.
My 2011 RT has done that since day one... I did not worry about it and now have 21K miles... Still does it.
Bob
