BajaRon
Well-known member
UPDATE!
See Post #7 below...
I sell quite a few brake pad sets so I stay pretty connected to the Spring Clip issue. These pesky little buggers are very hard to break or even damage. But they will jet off in most any direction and end up who knows were when removing or installing them. That is why I recommend using a rag to surround them and the area around them when removing or installing them.
Still, there are a number of us who don't do that and lose a clip (or 2).
So, what to do?
For awhile last year the EBC pad sets I was getting had spring clips included. It was a very pleasant surprise to me and to my customers. But the last 3 orders I have received (including the order I just received) of fresh new pad sets do not include the spring clips. I'm not sure what is going on with EBC. Are they going to supply spring clips with their pad sets or not? I have not been able to get a clear answer. But it is clear that, right now, they are not included.
So, what are your alternatives if you lose, damage or break a spring clip?
1- You can fabricate one from similar diameter piano wire. They won't be pretty but they will do the job.
2- You can post here on Spyderlovers and see if there is a blessed soul who can supply you with one.
3- You can purchase a set of BRP pads as they are the only for sure source for these spring clips.
I wish I had a better option for a spring clip need. Hopefully, EBC pad sets will start showing up with spring clips again... SOON!
So, what to do?
