brake extension
Paul A
I have a 2011 RS5 with Seal Floorboards. Does anyone know of a brake extension that will put the pedal to the front of the Sealboard?
Thanks, Paul
short answer is no. You will also need to add some extra springs to the brake pedal to off set the added weight of the brake pedal with Jon's supplied brake extender. There is string on the forum that shows how one person did it; the problem being his was an RT. The routing of the springs is different on the RS and ST's. Nice floor boards but you have to get inventive on the workarounds for the brake pedal return spring. Good luck.
