Brake Extension Arm Question
Why is it hitting; is the extension flexing under pressure? :dontknow:
Can you try mounting it up on top of the BRP arm?
Good luck! :thumbup:
Mine just taps the floorboard as the "Breakaway" occurs...:thumbup:
How much more travel do you have, before the floorboard drops? :dontknow:
Curious. ....🤔
I notice they have an BPE2 but also have a BPE1 offered. If the system is bled and at it's best you could mount the extension on top of the stock pedal to give you more clearance. I would, howerver, check to see why the floorboard is not breaking away...:lecturef_smilie:
