Bolt size
Nico75
Hi all ? Does any member know the size of bolt which holds the MASIVE cat under the Ryker
Is it A F / metric/ Witworth what size spanner is needed. Best regards Nico 75
Not right off...
But if you are going to do your own work it would be good to have a set of Metric wrenches and sockets. :thumbup: Only that wheel nut 36mm is an off size
Adjustable wrench or Crescent? Isn't the 36MM for the rear axle nut, not the Cat mount?, Pretty sure that's why BGraig is :clap:
Hi all that replyed to bolt size I think we are getting mixed up Its the bolt holding the big silencer / cat under the bike ,not 36mm for wheels ! Regards Nico 75
Here's the easiest way to find the answer: go to this web page and drill down to your model Ryker and look in the Engine Exhaust picture. I think the bolt you're looking for is PN 250001079, Hex Flanged Screw M10 X 50, and is the same for both models, but I know nothing about Rykers. The online catalog says "Not Available" and that usually means the part number has changed. Call your dealership parts department and they should be able to tell you the updated part number. Are you blokes still using Witworth over there? I thought they went out with MGs and Triumphs (not motorcycles).
