body panel grommets
lookerjdc
does anyone know the part number for the rubber grommets that the body panels punch in to?
I've searched a couple of websites that have the OEM exploded parts views but I'm not sure if the part number I am thinking is the part is actually the part I need
p.s. my dealer is a putz.........
Grommets - way to save them from falling out....
Hello my spyderlover friends....
I saw on a previous post and also have done on my 2012 Spyder RT Limited --- put a small nylon cable tie around each grommet to it's mounting hole/frame. Might hold them in better, but will definitely help you not lose them. I had one fall out (found it luckily on my garage floor) and I thought about the previous post stating to use cable ties. Haven't lost one yet by this method!!
Everytime I take a new panel off, I remember to do this to the exposed grommets. Over time, should get to them all.
Cheapcycleparts.com is a good site to find most part numbers. They have exploded views you can reference and the part numbers below.
