Body panel fit?
woodz428
Our 2008 Spyder was delivered 2 days ago and I have been looking it over, setting and adjusting anything I feel needs it. One thing that I noticed( I can be pretty anal about this stuff) is the fitment of the side panels to the top panel under/behind the bars. The is a noticeable gap and what appears to be a tab on the side panel, with about a 1/2"(13mm) gap between the two panels. The tab is visible even after pulling the screws and realigning it. Is this common, or do I need to remove a few more pieces to get them all aligned? Thanks,Woodsy.
The tab should fit under the top panel. Soemtimes a bit tricky to get fit right. If necessary, loosen the Y-panel (top) and push it down a bit before you tighten it. I have considered extending the tab on one side of our Spyder, or covering it with rubber, since it pops out readily on bumps on one side. The other side fits fine. Inherent in the breed, I guess.
