Bob T.
Bob T.
Has anyone put more than 18lbs of air in their front tires on the Spyder RT? the tire says 30lbs. I just rotated mine at 13315. they worn down pretty good on the inside of right tire and outside of left
Sounds like you better have your dealer check the steering sensors zero settings and your suspension bushings. Also check for a bent tie-rod. Tires worn inside one tire and outside the opposite one indicate steering that is off center. Your Spyder sounds like it is fighting itself, unless you have a lot of severely crowned roads in your area.
