stevencovert
Hi all,
Bought a 2016 RTS. Wanted the bluetooth kit, parts guy handed me the BRP kit (wiring harness with the SENA). Watched some videos on installation on youtube. Went to install, and my radio is not like those in the video. Mine has one big connector; the ones in the videos had two - the second empty one is for the CB kit. So now I'm puzzled :banghead: I'm assuming BRP changed the radio in 2016 or earlier. Sooo..
I see the connector is full - every hole has a wire. There has to be (I HOPE) a pair of wires for the master audio that I can connect to the SENA. I am using the GPS 1/8" plug wire tied to the frame for my phone (via a 6' extension cable run up to my X-Grip). I put on Pandora and use the GPS. The USB and 1/8" female jack in the trunk are inputs. I've found nothing in the wiring diagram that says a separate plug exists. Being that all wires are in the connector, I assume that means there are connectors located where the XM and CB would mount. Based on what I see, I can't use a wired intercom unless I buy the $800 CB kit because IT has the round DIN connectors in the harness.
I currently have a pair of uClear bluetooth intercoms. I paired them to the SENA for fun, plugged my phone in. I heard the music & GPS fine, until I realized I can pair them together for intercom OR pair them to the SENA. So it's either music OR intercom not both :banghead::banghead:. I would be happy with the SENA if I still had intercom! I play music and use my phones GPS. I see tons of cheap BT helmet intercoms on Amazon that say they connect to 4 or 6 devices, thinking of dropping the uClear.
So has anyone integrated bluetooth on a 2016/2017? If so how please
ray: !! Or have a BT system that lets you hear the phone in both helmets AND still have the intercom?
Thanks!
Steve
Thanks!
Steve
