spydermyke990
I was charging up the smh10 and decided to check and see how well the "firmware update" would work, so I registered the unit on sena's website, downloaded the device manager software, and sure enough, sena had recently release a firmware upgrade, so I made the change, as well as playing around with the phone & intercom vox settings. After the update, I tested it by pulling the dongle off of its bracket on the sts, re-paired it with the smh10(the update requires deletion of pairing history), then took an audio cable and connected my ipod directly to the dongle's aux input. The result was a higher sound out put into the helmet speakers, enough to make me turn down the volume so that my eardrums didn't implode!! Then I put the dongle back into its spot in spydie's frunk, threw on the gear, and took off down the road. after I reached highway speed, I had difficulty hearing the music, and the intercom feature kept cutting in and the unit kept blaring "intercom pairing failed!!" into my ears, I went back to base, plugged the sena back into the computer, and re-disabled the vox settings. It turned out the wind noise was activating the intercom and interrupting the tunes! (I think sena needs to come up with a noise cancelling mic) I headed back out on the road, and switched the tunes back on. Not a bad improvement.the sound was a little bit better considering the wind noise coming into my helmet, but the big difference was I didn't have to turn the volume all the way up to hear the ipod, so there wasn't as much of the background noise (buzzing and static)in the speakers, and running through a couple of playlists I ran out to Watkins glen and back.
