Bluetooth Dongle for audio
whiteyron
Is the Dual Stream Bluetooth Stereo Transmitter by Sena the same as the Bluetooth Dongle offered from BRP? Is this a plug and go device? I assume this will give radio reception thru my Sena head sets, correct?
Thanks
See my post and video about it in the DIY forum.
They are the same unit but you need a special cable that BRP won't sell separatly .
Bob
SM10
If you want to save a bunch of
$$$$$$$$ I have the SENA unit
on sale right now and if you watch
the video on making your own cable
all will be right with the world and your
spyder
Enjoy
motorcycledave
Thanks
spyder
Enjoy
motorcycledave
Motorcycle Dave could you use your influence with Sena to change the firmware on the SM10 so that it is user selectable to have the unit turn on and off with a switched power source. Like how a GPS or Dash Cam works. I would buy one right away if they would make that change.
That probably would require a hardware change to the sm10.
I could make a simple circuit to do that but it would require you to take the unit apart and tap onto the hardware switch.
Bob
