Biosafena
Over the winter I installed a Stebel horn on my 2014 RT Ltd. I installed it in the same area as the factory horn (which I removed) and used the factory horn wires as the trigger and ground for the horn relay. The main power and ground are supplied via dedicated lines directly to the battery. I tested it briefly following installation and all seemed to work well. Today I went for the first ride of the season and tried the horn while riding. It sounds great, but every time I hit the horn button, it kicks the cruise control off and gives you a check engine light for a few seconds. Anyone ever hear of anything like this or have any suggestions. It strikes me as an RFI type issue, but that is just a guess. I installed the same horn on my 2012 RT Ltd and it works fine with no issues, so I am not sure why this installation has an attitude.
