block off plate question
cmgross
I just installed the upper block off plate on my RT and now the heat hits me directly on my leg. I have a grill over the lower hole. Is the grill causing the heat to come up onto my leg? Also can you put a block off plate on both the upper and the lower?
Not sure if you can block both but you must remove the belly pan. If you didn't already you should remove the right side belly pan for more air flow.
