Chaynes68 ... thanks for all your photos , drawings etc. I just completed the 4" riser install on my SE5. You're right about getting to those 2 tie wraps in front - they were challenging. After I cut those 2 , I had plenty of slack. As far as the risers themselves are concerned. There were only 2 issues that I think may have already been address on other threads
1) Since the spacers are different on a SE5, the pre-drilled notch in the new bars don't line up to the plastic pin in the control housing - Just have to drill another notch a little further down.
2) Either the recessed hole in the bottom riser clamp is not wide enough or the hex bolt heads are too big - Take your pick. They will go in but the hex bolt head starts seizing against the bottom of the recessed hole and doesn't allow the clamp to fully tighten - even when the bolt is tightened to the max ... and I mean max. I just took the 4 riser bolts, my bench grinder and took off 3 smidgens off the diameter of the hex bolt head until it would rotate smoothly in the recessed hole without binding up.
Aside from the little "challenges", everything else went pretty well.
Now for the good part ....... these 4" risers make a world of difference ! I can sit up straighter, my hands aren't constantly going to sleep, seems easier to turn, legs don't seem to be as cramped etc.etc. ALL POSITIVES !
Actually, I don't see why Mr.Magic will have to redesign anything. Just make the groove in the new bars longer and check out the problem with the lower clamp / hex bolts.
AGAIN - THANKS CHAYNES68 !!!!!!!
