shadow0401
Have read several discussions about the RT vibrating at different rpms/speeds. Some have pointed out to check for loose engine mounts, engine touching frame etc.
One post I read the owner had his belt adjusted four times I think and all it did was change the speed and rpms when the vibration came and went.
This is just a thought: Has anyone checked to see if the rear sprocket is running true and true with the rear wheel?? If it is not this would cause the belt to loosen and tighten and ( I think ) make the belt vibrate at different speeds regardless of how tight it is. Just a thought.
Dave
Dave
