Belt Tension Adjustment with a trailer hitch
smartin436
Hey Guys,
How do you adjust the belt tension with the BRP hitch installed on 2011 RTS? Can't get to the adjusting bolts.......can hardly see them....
Can the hitch be removed without removing the axel?
Steve
just remove the long bolt that goes through centre of rear axle that holds hitch on.Then remove hitch staight back,I use a low rebound rubber hammer,watch and dont catch any of the cables on the right side, only a 10 minute job then its easy to adjust belt tension
