I changed my tire a couple of weeks ago and finally got a good ride in. However, when I ride it appears the belt is on the inside edge of the tire sprocket hub. I did not move my tensioners and I am not sure if it is rubbing to much or not. Before the tire change, the belt looked like it was in the same position however I think I smell a faint rubber burn. Not sure if it is the new tire or the actual belt. I can pull the belt to the outer edge of both sprockets (drive sprocket and tire sprocket) and it will move right back to the inside of the tire hub and the inside of the drive sprocket. Should I leave it as it is or move the tensioner to get it a millimeter away from the inside tire sprocket?
