PCBeachBum
For about a month now my Spyder would go into limp mode and I would get the usual scrolls across the dash board. Shutting it down and waiting a few minutes, I would restart it and it would be fine. Friday night, I noticed the battery light would come on and go off after hitting a bump in the road.
Saturday I took off the 2 of the left side panels to check the battery. The negative side was tight and checking the positive cable that to was tight but, the whole connection looked like it was off and not straight, like the negative side. I'm suspecting that the terminal is cracked inside and am wondering if this has ever happened to others. I've never heard of this before and know there is a first time for everything. I'm just wondering what would cause this. :dontknow:
I have never touched the battery before or had a need to. The last time I saw the battery before this was when I had the 02 sensor mod and plugs changed about 2 years ago and just replaced them with Iridium plugs. Long before the plug change it was at the dealer for the 2nd generation DPS.
I've never heard of this before and know there is a first time for everything. I'm just wondering what would cause this. I just read a post about weather change and it has been going from warm during the day to cold at night. I would expect nuts and bolts to come loose but the whole battery terminal. :shocked:
It still runs but its not going anywhere til I get a new battery in it. I can see myself pushing it home and the bad thing is? There are no hills here to coast down.
