battery tender
flatman
help..non tech kind of guy .. what is the best way to hook up a battery tender junior to a 2011 rss.. weather has finally turned to snow and finally have to call it a winter..any help would be appreciated
You have several choices. "Best" depends on your preferences and mods.
1. You can clip the tender to the jumper terminals under the seat using the included alligator clips.
2. You can install the included pigtail to the battery terminals (inside the bodywork).
3. If you have an unswitched Powerlet or cigarette outlet installed, you can buy an adapter to connect to that.
4. If you have a heated gear pigtail installed, you can buy an adapter to connect to that, too.
flatman,
Thanks for reminding me. I put the spyder up this past Monday and forgot about the tender. I have #3 above (on my gs), which makes it easy.
I seem to recall that one of our own hooked his up under the seat, but then had the whole deal short out when he closed the seat down on the wiring and ruhhed a bare spot... :shocked:
So I'd suggest throwing something like a rag down under there also to prevent the seat from latching shut.
On my RS I connected right to the battery then brought the dongle end up under the seat at the positive (+) post. It sits right in the same recess that the positive post sits. When charging I lower the seat but don't latch and everything sits nice.
Pretty easy hookup and there is plenty of room to work with.
I hooked my pigtail up directly to the battery and routed the plug under the seat. Everytime I park the spyder I simply raise the seat and plug her in. :thumbup:
:agree: And the seat will shut with no problem if the plug is in the right spot!
I did option 2. The best way to charge a battery, is to goto the battery terminals.
Mike
BATTERIES IN WINTER
If you plan to ride during the Winter dis-regard this post............If you plan to just park it for a few months, I would remove it and bring it inside and put a battery Maintainer on it.......JMHO....Mike :thumbup:
Velcro will hold your wires in place
I use velcro to keep my charging wire in place when the Battery Tender is not hooked up. Works good to keep the wires from being crushed under the seat. If the charger is hooked up, I leave the seat up to remind me to disconnect before doing anything else.
Connecting/disconnecting
If using option #1.
While charging: Always connect the POSITIVE (+) cable first to avoid damaging the electrical system of the vehicle.
Once charged: Always disconnect the NEGATIVE (-) cable first to avoid damaging the electrical system of the vehicle.
