Battery removal info
Brentc
So I'm getting ready to add a 12 volt plug to the front trunk of my 2014 rt and it was suggested that removing the battery would give me a bit more reach around access to secure the retaining ring. Sounds good to me so I happened to be in the Tech Spark manual that I purchased and was reading the battery removal section. The very ;last step in the install says to "Turn ignition key on then off to prevent battery drain from the DESS system." I had never heard that before so I wanted to either pas it along as useful info or see if others have heard of that........:dontknow:
