Battery hookup
Clary
I want to hookup my heated vest and heated grip wraps . Can I use the round connectors both at the same time to the battery posts (one on top of the other) for them to work.don't want to hook them up permanently as the cold weather is just about over(we hope)
Sure..!!
the thing to watch is the length of the bolt on the battery. Some need a longer bolt but if you go to long they won't tighten down properly. You need a good tight connection...:thumbup:. You can also use the connections under the seat...positive anyway....
What year do u have. I have a 13 rs and if you take the trim off where the coolant tank is there is a hot and ground on the opposite side of the tank. Just a suggestion
The connections under the seat is what I was referring to , so I will use that connection,thanks
