BAKER BUILT WINGS
tmcquain
I just put on the Baker air wings on my RT. Will anyone with these installed send me a picture on a RT. I need pictures with all four panels uppers, extra panel and the lower wing as well..I want to make sure I have mine installed correctly. I'm just not sure 100% sure that I have them installed correctly.
Thanks in advance....
Tim
Does this help?
MY PICS
The lower wing doesn't open as wide as the others, and the inner panel doesn't seem to be as low as it shows in the limited amount of pics I have seen....I still get a lot of wind on my knee from below the inner panel. Any ideas ?
View attachment 140409View attachment 140410
Looks to me like you need to turn the brackets around where they attach to the brackets you stuck on the chrome side panel trim. (probably need to swap top for bottom or left side to right side). Mine turn just like the upper wings and I think that is why.
Actually I think I mis-guided you on the above. I re-checked mine and it is your 2 upper panels that the brackets need to be reversed - sorry.
Your bottom panel is just like mine and I think my set up works great.
By George I think you got it....after what Krazykat just said and looking at a picture of the mounting installation I think he hit it...I think the hinges are reversed...
THANK YOU SO MUCH FOR YOU HELP !!!
TIM
TIM
Glad I could be of assistance - they really help, especially when it gets cooler (never say "cold" in Florida) - enjoy.
Pictures from the back side. Hope this helps
ToM
Enjoy the Ride
Life is Good😃
Install Help
Hello Thank you for your purchase of your Baker Built Air Wings. The only thing we see that is wrong on your install is the Air Wings w/ Uppers are on the wrong side the pivot point should be at the back of the wing meaning the angle points the other way. Just flip-flop your sides and you will be all set. Your inner panel is on the correct side as well as your lower wings are correct. The only panels your need to switch is the two piece unit that is a set and you should be all set.
Again we thank you kindly for your purchase and if you have any other questions or concerns please don't hesitate to contact us, we strive for complete customer satisfaction. You can email us at [email protected] or call us at 1-800-451-9464.
Thank You
Baker Built
Silver Spyder is Right Side View
Yellow Spyder is Left Side View
Thank You
Baker Built
View attachment 140428View attachment 140429
Thank you, don't know how I can mess stuff up like that but I do, I just thought something was wrong, it didn't look just right....Thanks for everyone's help on this...they will be swapped tonight...
we are all human and we all make "mistakes" its a simple fix. glad to have helped as well as everyone else who helped you. enjoy your riding. and again we thank you!
