BAD BATTERY
jtoro1
I had a bad battery only 10 vdc when load tested but 12vdc with no load, I watched Bob Finns video to get it out, what it does not make sense is that it would not start by jumping with my car or my battery booster XP1 . I thought I had other problems that I would have to take it to the dealer,but to my surprise I put in the new battery and the bike started right away. I had some codes which I cleared by taking the key out and waking away. Time to ride again.
:congrats: I'm glad to hear that you were able to find and fix the problem. :clap: :2thumbs:
His videos always seem to make the work seem less daunting; don't they? :D
If you had a shorted cell (very possible) then jumping it with that bad battery hooked up may not work as the short is taking down anything you apply to it. I assume you did not try to jump it with the battery unhooked as a test?
Either here nore there though since your fixed anyway.
Bob
Bob
Yes I tried to jump it without the battery too and it wouldn't start very strange because I knew it should have started
When my 2008 GS had a bad battery it would not start with a jump
But new battery fixed the problem
Hmmm, I was taught NEVER to try and jump start an EFI/computer controlled engine without a battery connected.... even if it was a dead battery it would be more likely to stop you frying the computer!! :yikes:
And I have seen a number of computers really fried after their owners tried jump starting without a battery wired up; but never seen a computer fried when the jump start instructions were followed properly, including keeping the dead battery wired in. :shocked:
My guess is the jumper connections just weren't good enough to carry the necessary current from the jump battery.
