I am so tired of my battery dieing if I forget to leave the tender plugged in (and I seem to forget A LOT)....
Question: Is it a crazy idea to keep a backup battery in the trunk plugged in? I'm thinking they would run in series, is that correct?
this battery is less than a year old (2nd since 2010)...sat two weeks this time, but it will do the same if it sits a week. has always done this, even with original battery. when I ride it daily, no issues, only if I let it sit several days without the tender
Good Luck! :thumbup:Thanks for the advice, that's why I love this forum....you guys have come thru for me again. I will pass on my dual battery idea and have my dealer keep it an extra day or so to check this out on my next service
I'm looking to carry a second battery in my trailer to power a CPAP at night and charge it from the bike during the day. Two cautions I figured out. First, like you said use a battery isolator to keep either unit, in my case the trailer load or bike, from discharging both batteries. Second, even if you use an isolator make sure it doesn't have an option to feed back to the other battery for starting, UNLESS you have heavy, as in 6 or 4 gauge, wire connecting the two. If they are cross connected with something like 12 gauge wire and the backup battery starts to feed the starter you will have one hot burned up mess on your hands!To further beat a dead horse :bdh: I would say that if anyone decided to do it you would beed a battery isolator too.
I don't remember exactly without looking it up in the manual, but if you are hearing a high pitched sound after the bike is turned off it's something in the fuel system holding throttle plates open, I think. It lasts for about 40 minutes, then turns off. I suppose in the OP's machine it's possible that item may not be shutting off like it's supposed to and that would run a battery down in short order.Also in the camp where it sounds like something is draining the battery.
get one of these and keep it in your trunk. No need to keep it plugged in, just recharge after you use it. :thumbup:![]()
go to amazon .com and type in anti gravity battery
Cruzr Joe
If you call Pitbull they have a killer battery backup that will start a dead car 20 times before needing charging. I carry that one with me. :doorag:
PitBull Phone: (417) 863-1418
