Backdraft Eliminator designed, built, and installed!
Finally got my Backdraft Eliminator designed, built, and installed. Had one on my Goldwing and loved it. Also creates a nice space for decals. This post is about the shield on the passenger backrest, not the flags.
Nice flags!!!! My wife is my back draft eliminator :joke::joke:. But really, I've found that a good VENTED windshield and adjustable winglets under the windshield moves the still air bubble away from both me and my wife. Also, and even better, is a bag on the safety chrome trunk rack.
Lew L
Joel, FWIW, from Title 4 United States Code, Chapter 1, § 7. "Position and manner of display
The flag, when carried in a procession with another flag or flags, should be either on the
marching right; that is, the flag's own right, or, if there is a line of other flags, in front of the
center of that line." You should reverse the position of the two flags on your Spyder.
That has been corrected since the photo was taken.
Looks like it would create drag.
Not any more than the person/s sitting on the Spyder as they ride! :rolleyes:
Besides, while the Spyder is moving forwards with someone onboard, the air flow just there is a bit turbulent, but mainly towards the front of the Spyder, hence the need to stop or eliminate 'the back-draft'! :thumbup:
I suppose so.
It really works! And, it works really well when there is no passenger. It helps create a bubble and reduce wind turbulence. I rode a couple hundred miles today and what a difference it made. I also noticed the flags were waving the correct direction. Without the backdraft eliminator, the flags were actually waving towards the front of the spyder. They really were! That is how much backdraft there was.
Here is a picture of the one on my Goldwing:
It is a actually mounted to the trunk lid and is 10-1/2" tall because the piece of plastic i had was 12x16. It has 2 tabs 1-1/2" long that attach to the trunk hinges. There is also 2-sided tape used.
