Auxiliary Switch
Fonz
Is there a way you can turn on your radio or Ipod, without draining your battery or at least use minimal power ?
You can leave the radio/iPod on after the Spyder is shut off by holding down the "MODE" button (I think) while switching off the ignition. It will run down the battery, though, and the only way to turn it off is to start and shut off the Spyder normally again.
Motorbike Professor...............I think you are more like the "Rain Man" of motorcycles! Seriously how in the heck do you remember all this stuff?:bowdown:
:bowdown:
This forum is very lucky to have several members with incredible knowledge, now a days companies charge for this kind of technical support, thanks to all for the freebies!
:bowdown:
:agree: +100 Thanks to all the Techies out there.:thumbup:
After you turn the switch off just hold the mode button and the radio will come on. I think you have like 20 sec. after turning key off to do it. it would like be the ACC on a car.
After using the mode button to turn the music back on, pressing the emergency flasher button on/off will shut the radio off. No need to turn the ignition on/off.
I'm glad someone asked that question, and thanks for the very informative answers guys!! SL is THE place for answers:clap:.
Mode button and Radio System - Spyder RT
Ref - Keeping the Radio on using the Mode button
Is it only for the 2011 & 2012 Models - I have a 2010 Spyder RT - S SE5 Model and if I use the Mode button whilst
switching off - The Radio will only stay on for about 20 Secs then it switches off
Also I select Region B for radio channels UK - But if I use the Aux facility the radio will reset back to Region A USA & Canada, When I next switch the back Spyder on.
Anyone know if the latest Radio being fitted to 2012 models allows you to select any frequency as a manual
operation as opposed to the pre-set ones e.g. I want to set a frequency to 107.00 fm but the nearest is 106.90 which will not work
Could a dealer make any adjustment in the BUDS system to the Radio software
Thanks
Eddie Sheppard
