New 2023 RTL 500 miles and have the C1290 code. Put a trickle charger on battery and code goes away. I also noticed that when first started and the code was present the engine RPM was up to 1400. I read this is to charge up the low battery.
Understanding the batteries are junk from Can AM have a couple of questions about replacement. In the manual it states that you need 21apm hour battery. Did not see CCA need but have read on here it is 350.
YUASA YTX24HL-BS states 21 AH and 350 CCA. Is this the correct YUASA???
NOCO NLP20 is 7 AH and 600 CCA. Is this the correct NOCO? This would also need a different trickle charger.
Biggest concern is the 7 AH on the NOCO. Is this a concern going forward? Currently do not use heated gear, I do have a trailer, and then typical phone charging Carpuride etc.
Thoughts and personal experience appreciated.
Thanks
Thanks
