You're not holding your foot to close to the peddle to activate the brake switch, are you?:dontknow:
I never keep my foot on the pedal. This code and the brake light is on all the time.
Update:
Today I did a brake fluid flush. Pulled a full reservoir of fluid through there lines.
1) Jacked up front of bike, removed front wheels.
2) Sucked all the fluid out of the reservoirs (as much as I could get with my brake syringe).
3) Filled reservoir with new Dot4.
4) Using a hand vacuum pump, I drew fluid through the bleeder valve at right front wheel until the reservoir was pretty low. Refilled the reservoir with new Dot4.
5) Repeated this for each brake bleeder valve.
6) Put wheels back on, torqued them and did a test ride.
Okay, did I get all the old fluid out, probably not. Do your ever? But, I got most and am comfortable the fluid id good.
Brakes work fine, actually great.
The next thing I did was to remove the fronk liner so I could get to the battery. My goal here was to install a battery tender cable to the battery so this winter I can leave the bike on a tender. To my surprise, there was already one there. When I followed the wires, It is a water tight box/plug that is the same plug my tender uses and it is cable tied to the front right suspension on top. Easy access.
Since I was there, I disconnected the battery for about 5 minutes in the hop the computer would reset/reboot.
I put everything back together and the brake light is still on the dash and the code is still there. And now it has a friend.
Codes now showing in my code list:
C1048
C232C
No idea why the pic is upside down?
OMG. Get off of the floor and stop guessing. Your Service guy is correct. A fluid level sensor, not a pressure switch. Right from the BUDS2 Fault Code Database for the 2019 F3:
C1048:
Cause: - Brake Fluid Level Switch shorted to Battery+, Ground, or Failed.
Action: Check for damaged Brake Fluid Level Switch wire, connector, or switch. Replace as required.
I'm sure you know where they are....but just in case, see pic. Doesn't say which one. Process of elimination.
Part number: 705601073. In the parts system it's called an Oil Level Sensor. Has been from the very beginning. Don't know why. It's correct on electrical prints.
Granted, all of those other maintenance items you did needed to be done, anyway. And, if this is the original battery, it needs replaced, before it lets you down, even if you didn't have any codes.
