Anyone installed Top Case LED Kit from TricLED? Any advice?
Revjames
Has anyone installed the TricLED Top Case LED Kit Top running red, brake and yellow turn signal on a 2020 or newer RT Limited? Any advice you can offer on wire routing from front of top case back to tail light harnesses? Thanks in advance.
Just finished installing them on a friends 2022 F3L. The main difference is that the F3 topcase is not meant to be completely removed so the wiring is more "permanent". On the RT, you'll have a hard time wiring them so that the case can be easily removed. There are 3 screws on each side of the top case lower side covers. Remove them and the side covers will drop down and off. I ran the led strip wires under these covers and into the main area under the topcase. From there you can go to the tail light harnesses. Remember to disconnect them at the "y" cord if you want to completely remove the topcase in the future.
