Anyone ever installed Highway Pegs on a Spyder GS?
SamHuskyguy
Has anyone ever installed Highway pegs on a 2008 Spyder GS? I saw some that attach to floor boards, but mine has pegs not floor boards. Just looking for idea's.
Thanks
Sam
You really should always try to do a bit of a Search & spend some time reading to see if your question has already been asked and answered before starting a new thread, Sam - there'll most likely be something here about just about every question you can think of on these older models already here, if you look! :ohyea:
A fairly quick search shows that there's a fair bit of info about Highway pegs on GS Spyders here already, most likely answering or at least narrowing down the scope of your question - just go back to the main index page for Spyder GS/RS Sport (to get back there, just click on that < term in the address line just above our Sponsor's logos, it's where you found the ' + Post New Thread' button ;) ) and then go over to the far right of that page & click on 'Search Forum', it's just below the block where it says Threads 1 - 30 of 1930 & shows all the page numbers. That'll open a Search Bar for just this particular Spyder GS/RS Sport sub-forum, and you should type 'Highway Pegs' into the text field; tick the 'Show Threads' button below that; and then click on the 'Search' button. Once the results page comes up, you can select which threads to read by seeing which thread titles look most applicable to your question - yes, there's probably lots of threads listed with titles that don't seem to apply, but that's generally because, despite being asked NOT to use the 'post title' field, many people still do, and someone posting in that thread has used at least a part of your search string in their post titles.... still, if you can't find a Thread that answers your question, you can always re-enter the search using exactly the same search string, only this time tick the 'Show Posts' button - you'll likely get thousands of posts in the results rather than hundreds of threads tho, so it can be a bit daunting and harder to identify those directly applicable to your question, but if it gives you the info you're after... :thumbup:
Mind you, many of the parts and accessories that once were available for the GS/RS Spyders may not be any longer; so you might end up needing to adapt something for a newer model with pegs to get something that'll work on your GS - or maybe you'll be lucky?! :dontknow:
Good Luck! :cheers:
