ricford
I purchased a CompCooler Motorcycle Rider Solo Cooling System. It is seemingly the best system, though certainly arguable. Are there any others who use the system? I had another similar system, but they went out of business and the vest tubes calcified, no water would pass through. I have one problem and that is long term usage, i.e. when I take a ride that is longer than the ice in the solid ice container. What does one do on the return trip; on another day's ride; or when the original ice melts? I want to use distilled water around the ice block (it is frozen solid inside a plastic container) to prevent the tubes from calcifying. I've got it mostly figured out, but I'm curious to know if any others have used the system, and how you solved the problems of multi-day trips away from home.
https://www.mycoolingstore.com/
