Anybody installed different Horns on an RT?
RT Horns
Has anybody installed different horns on a RT to get rid of the wimpy one tone originals?
Hello TBL,
we sells air-horns for RT with specific relay. I'm including the link for the product here, in case you want to get more info on it.
We launched this at Spyderfest, for on site installation and we have been selling quite a few of this online .
(we currently have a promo for 4th of July, code: usa10)
https://www.tricledusa.com/_p/prd1/4626469951/product/super-loud-131-db-air-horn-with-safety-relay
thanks in advance for letting me chime in :)
- Cindy
There you go....
Instant gratification...and they will install them as well...:firstplace: probably can hook it up to a led light show while they are at it..but seriously there are other horns and many have changed them to be noticed...
Yes I did
Install a better horn. The Strobel with relay. It's SOOOOOO much better.
Wimpy horns cause------------Kaos
Air Horns
Hi, I installed a set of air horns with a compressor and relay, I had to make a bracket for the horns. Works great and is loud. I also utilized the wiring and horn switch along with adding wiring for the power and ground. They know I'm there NOW!!!
Wolo Bad Boy from SPYDERPOPS
Sounds like a horn should-- but not obnoxious. Just click on Spyderpops link on the HomePage. Easy replacement install on the RT and easy to move from one RT to the next... if you trade up.
We mounted it right where the OEM P.O.S. horn sat.
We didn't use a relay when we mounted it. In hindsight: that may have been a mistake. I believe that adding a relay to the system will protect the OEM horn button wiring.
The Stebel does use a bunch more power, to make all of the noise! nojoke
Bob, where did you mount yours? Hidden under the tupperware or what?
Does the Nautilus have a relay or is it direct wire to power from the switch?
Pete, that's one thing I forgot to mention your new bike has. The Nautilus horn is under the panel with the left side baker wings installed. I used it a few times and it is LOUD.
