Any hints/info on S2S Tank Badge Removal?
tomknotts
Good morning, Everyone,
I am looking for information on how to remove the S2S "99" badge on the tank (area just in front of the seat). I thought I saw a video on instructions about this a long time ago, but now I cannot seem to find it. Any help would be great?!
Thomas
I thought that was the build number; guess not, since the wife's has same number.
Does luggage not come with S2S's??
No, for $33k you're lucky you get a driver's back rest. They will take that away soon too, just like the other Sea to Sky's that came with them at the start!
I should add that I want to remove the badge to 3m film the central tank and then put it back on. I thought I saw somewhere that it had pins holding it in?
Only the first year S2S model came with luggage, fatboy. BRP very quickly dropped that “wasted profit" - now there’s a surprise. :roflblack:
Pete
If the badge is held on with two-sided tape, which is the popular way to do it these days, I have had luck with dental floss or fine nylon fishing line. Go under the badge with a sawing motion and work your way through the tape. This will also keep the badge in good shape to reuse. Some have applied a bit of heat with a hair dryer, but I never had to do that. The residual adhesive can be removed with a dab of WD-40 or something similar. Don't use any harsh chemicals because paint damage is possible.
