Any Highway Pegs for a 2022 RTL with OEM Floorboard Lights?
campermac
Has anyone out there come across any Highway Pegs for the 2020+ (specifically 2022) RT Limited that has the OEM Floorboard Lights installed?
I have looked at all the sites and cannot find anything so I am asking in case I missed something.
thanks
Keith
From what I found out from Lamonster the floorboard lights use the same mounting holes as these highway pegs and others as well.
Those are the Show Chrome boards everyone has and they will not work with the boards that have the OEM lights.
Thanks anyhow.
Your saying OEM floorboard lights, like they come as standard equipment. I just bought a 22 RTL. No lights on my floorboards. Do you mean BRP sells them if you want to add?
BRP does make their own floorboard lights P/N 219401038. Matter of fact they just came out with the passenger floorboard lights as well P/N 219401153 and I already have an order in for them once they are released in October.
https://can-am-shop.brp.com/on-road/ca/en/219401153-passenger-floorboard-signature-lights.html
The BRP light are white only, they do not switch to amber for turn signal function but they are a good quality light assembly that bolts to the bottom of the floor board and is a plug and play wiring them.
Released in October?
I have the Passenger floorboard lights on order since they were announced. Its November now. Where are they? I would like to get them before the snow flies here in MN.
Same here. I'm not really in any hurry but you would think they would have had them in stock by now. Afterall, there is no chip involved. Only the castings and led strips.
What is the advantage to the floorboard lights ?
The fact that they are hella bright so you get seen much better (day and night and especially from the side). They are of impeccable quality. And they look really, really good on the Spyder. Combine them with the A Arm led strips from Sling Mods and it will completely transform the look of your Spyder. Especially at night.
I spoke to a good friend of mine that is the Northeast Regional Territory Rep for BRP and he said that the passenger floorboard lights will not become available until they start shipping the 2023's and even then they will be several months behind so I would not look for them until at least spring time frame.
As for the Highway Pegs that can be used with the OEM floorboard lights, I worked with Keith and Nick at Spyder Extras and they sent me a set of the highway pegs along with an assortment of spacers and I came up with what we all thought to be a relatively easy fix. They are going to be updating their website along with Slingmod's sometime in the very soon future so that you will need to order them for the OEM floorboard lights or without.
I know this is an older post, but curious….
Are these the Highway pegs you sampled from them?
https://spyderextras.com/shop/detai...-RT-Floor-Board-Highway-Road-Pegs-SRT-2020HWP
thanks
Keith
Did you ever come across anything you were able to make work for you?
Thanks
Bill
Thanks
Bill
I installed the highway pegs LaMonster sells even though they say they won't work with the BRP floorboard led's. I had to grind the mounting bracket on a slight angle to make clearance. Not a hard job at all and probably took 5 minutes per side with my bench grinder. I initially started with a Dotco but it was taking too long so I switched to the grinder. They fit just fine with a little tweaking.
I installed the highway pegs LaMonster sells even they say they won't work with the BRP floorboard led's. I had to grind the mounting bracket on a slight angle to make clearance. Not a hard job at all and probably took 5 minutes per side with my bench grinder. I initially started with a Dotco but it was taking too long so I switched to the grinder. They fit just fine with a little tweaking.
Thanks, I’ll look into some of his kits…any suggestions or just any of them?
