Any alternative Air Compressors for 2014 RT's?
Does anyone know if there is any air compressors available for this, other than BPR one? If so, could you please let me know where I can get one? I posted earlier, that compressor still works, but getting noisier, and runs more often. Alot more often. Like every 10 minutes. Currently checking all the other possibilities, like leaking fittings, leaking hose, or air bag. Just trying to find out how to get to all this stuff, to check with soap. Anyway, still need to find out if there is a direct replacement, other than BRP. Warranty expired.
Yes, BRP would replace your (our) crappy compressor with just another one of their crappy compressors. Do a search on this site and there are several videos and numerous threads regarding aftermarket compressors for our spyders with DIY info and where to buy info.
Most all of your connections, dump valve, and air lines can be accessed from the right side of the bike! The pump is way in there you'll see the check valve, but not much of the pump! Good luck!! Hope it holds out for you this season.
