I have a 2015 Can Am Spyder RT. I just notice a little wet spot under it and found it was just a little antifreeze. Such a small amount it was hard to tell what it was. No where under the frame I could see where it was on or dripped off. I wiped it up clean and notice in about two days there was just a little water or antifreeze again. I removed the plastic under the right side wheel. Got a light up under and found the hose coming from the water pump was wet like it was seeping a little moisture. It has an oetiker hose clamp which cannot be tied. The diameter of the hose looks like it is 1-3/8 inch. I will get a new hose clamp and replace the oetiker with a regular hose clamp that can be tied. Has anyone else ever have theses clamps leak? I was afraid it might have been the water pump but every place was dry except around the hose connection. When I jacked it up where I could get under it I could see if it leaked directly from that hose it would not drip on the frame it would drip directly to the floor so I am pretty sure that is all it is. I never did like the oetiker hose clamps.
