Anti Freeze Leak
2faston3
Hello All:
While I was installing Ken`s Power Buss, and NMN High rise handlebars, I noticed a puddle of Anti Freeze under my wife`s spyder. As I had all the body work off I checked it out. Found a hose that runs from the top of the rad to the engine. And on the engine side there was a screw type triton clamp that while not loose did allow me a turn or two.
All better now...
2faston3
Better to find it leaking than to be on a ride and find it empty. Lucky to find the leak when you did.:thumbup:
I had a similar problem. Traced it to a cracked plastic inlet on the radiator reservoir. All better at BRP's expense.
