antenne
lmadsen
I purchased a short antenna and am having trouble getting the stock antenna out. I have a long nosed vise grips but it is so tight i can't get it to loosen. Need some suggestions from those of you that may have ran into the same problem.
Thanks
Larry
some have put a long socket over the antenna down onto the both head and used vise grips to get it unloose that way.
Antenna removal
Get you a socket that is the correct size and slide it down over the antenna with the antenna sticking thru the hole in the socket! a deep well socket works best! Then get a wrench to fit the socket, and you can get it off easy!
Carl
Found a cheap 7mm ¼ inch socket drill the inside to fit over antenna and soldered a wrench to outside and it worked perfectly.U don't need the wrench but it's in the tool box for anybody to use.
