cptjam
Registered User
Ann broke her antenna. Snapped off at the base. 7mm deepwell socket got the base out. I read on here you could fix it. Put the antenna in the vise between wood scraps. Used a new hacksaw blade to cut off cleanly. Put base in a drill press vise, drilled out remains. There is a tiny wad of metal wool, to make the connection electrically. Put wool in brass base, tapped it onto aerial; bolted on. Works perfect, cost a few minutes of time. SL rocks! The stuff you learn here is great! Joe
