Another question
wengerda
I cannot find the answer to my question, when downshift on your SE6 do you 1) keep giving gas to the throttle and release the gas slowly until complete doenshift or 2) you let the throttle off when downshifting or 3) it does not matter use the brakes, downshift and throttle off. Thank you.
Thank you, I do have a SE6 and I do release the throttle too, but other riders told me that you should keep giving gas when downshifting, I am not sure why.
Don't overthink it ... drive it just like you would your automatic car / truck.
It is Spyder magic :yes:
Holding the throttle in place and punching upshift is what most are talking about here.
The SE6 downshifts on its own quite well. Just apply brake (like on your car) and it will downshift at the proper place and time. I let it do its thing about 98% of the time. If I need to power down to the next gear for some extra power to pass, then I will manually make the downshift.
BRP has the SE system figured out pretty good. :yes:
Depends.....
When I'm slowing down & need to do it quickly, down shifting with no throttle helps slow the spyder faster.
If I don't have to slow down quickly then I just back off the throttle & use the brake. The computer takes care of the shifting great.
It's just a matter of what you are comfortable with. There is no right or wrong way when slowing down & down shifting. JMHO
When was the last time that ANY of you were slowing down, and still were feeding the bike any throttle? :dontknow:
If you're coming up against a hill that requires a lower gear, or a cage in front of you that needs passing: just click back on the paddle , and the computer will do the rest! :thumbup:
(You can never blip the throttle as precisely as the computer... :bowdown:)
