Another fix for the cowl issue with rubber tabs breaking
bone crusher
Alignment Specialist
There is another solution...quite easy...for the issue of the rubber tabs breaking on the underside of the cowl. Based on the law of physics, you do not need to strap velcro to the underside of the bike...you can attach the seat directly...this is because it is not the air that gets underneath that lifts the cowl off but rather the negative pressure above that creates a vacuum effect...so, the following pics show a velcro approach that works great. You want to put the soft velcro on the seat and sitting on it is not an issue...if you have the cowl on, nobody is sitting on it anyway...
http://www.spyderlovers.com/forums/album.php?albumid=145&pictureid=8374
http://www.spyderlovers.com/forums/album.php?albumid=145&pictureid=8375
Hope this helps anyone who needs some assistance with this issue...
