Lamonster
SpyderLovers Founder
I hate to say it but many times when I'm stuck at a long light I like to check my email to see if there are any fires to put out. I don't answer emails while stuck at a light but I will pull over and deal with it if it need be. It was always a hassle to pull it out of my pocket and do that especially if the light changed while I was reading my email. I knew right where I wanted my iphone to mount and I had a pretty good idea how I was going to do it so today I decided to get it done and it was a pretty easy deal and works great. :thumbup:
First I took the cover off of the bottom on the handlebars. You'll need a M3 allen wrench to get the four screws out. Turn the bars all the way to the right to get good access to those. I also recommend you stuff a rag under the bar just in case you happen to drop one of those little boogers, they will fall in the black-hole. nojoke
Then you want to check for clearance before you drill your hole for the Ram Ball to mount. You can see where I drilled mine in the pics. I used a thread ball with M6 threads.
I drilled my hole and mounted the ball and put the cover back on and it works great. Now I can check my email if I need to and I can keep an eye on on the weather radar too, I'll use that a bunch for sure.
Here's the pics and hope it gives you some ideas. The skill level is pretty low for this mod. :thumbup:
