Hi .. Im about to do the rear pads on my 2012 RT. looking in the manual I have for the 2010/2011 models, it says push the piston back into the caliper. Im looking for a definitive answer, as to if the piston just pushes back in... or is it push and twist clockwise. Mines a 998 so has the older braking system. Im looking at the easiest way to do this without having to take loads of stuff off..if its a simple case of pushing the piston in then I wont have to drop the caliper off.
If I do have to drop the caliper off to backwind the piston in, then im looking to leave the muffler on as that's gonna open a whole new can of worms with the rusted bolts etc. Reading the manual I have it says remove the parking brake set up as well.. does this just entail removing the cable and then the big nut in the centre of the black disk thingy? It cant be as simple as that can it? Ive searched for youtube vids for my model, but to no avail... im quite proficient on the spanners and don't see it as a complicated job, but im open to advice and any tips before I start....or a step by step guide..
