Am I missing a vacuum line, pic included
Bad-Day
there is an electronic device with a couple hoses and an electrical connector, that has an exposed port facing forward, is there a hose missing off of it? Right side of bike, beside the top left corner of the radiator.
thanks, luke
thanks, luke
If you have a Manual Clutch transmission, that would be your vacuum assist solenoid for your clutch. And if so, you're good. That's the vent to atmosphere port.
If not, then you better give us more info on your machine.
Yes it is a manual transmission, so I am good??? just seemed odd when I saw it. Thanks.. Luke
You're not the first to think it odd. BRP should have put a little rubber fitting with a foam filter on it. Probably not necessary but it would look finished. Ride safe.
