spyderwing
2012 Rss- 25000 miles. Spyder needs the laser treatment. Right front tire is toed in and very worn on the inside edge. Left front is fine and still has some miles to roll. Can I replace just the right front so I can continue to ride safely until I find and arrange the alignment procedure/ appointment. Once the laser is done, replace the left front also. This may take maybe a month-not sure yet. I would probably get Kendas for the fronts as they/ it has worn well. What about putting a used but good tire on the right front temporarily- until the laser is done so the ride is safer. Can I mix the fronts or bad idea? Please advise-I appreciate all your thoughts. Thank you. John
