Airhorn
Lots of people have and it's a relatively easy task.
Many people use the Wolo Bad Boy horn or Seibel (you can find these at many auto parts stores) and there are some others. You can install the new horn on the same mounting point as the current horn.
Although many people don't use one, you should install this using a horn relay, also available at almost all auto parts stores.
I just installed a Stebel with the relay. Stebel says their horn can use up to 20 amps, and therefore recommends the relay to prevent electrical damage to the bike's horn button or other parts not designed for higher power. YMMV.
And the difference
is AMAZING. The Strobel is MUCH louder than the wimpy a$$ stock horn. Its also louder that the WOLO " bad boy". I have both, installed with relays and have done the side by side comparo.
Wimpy a$$ horns cause::::::::::::: Kaos
See the trumpet air horns on mine in my sig photo. They work, get people's attention really good, and look good, I think.
