Air Suspension
flybuddy
Is losing about a pound per day normal? My RT came without ACS and when I would check the pressure it would seem to lose a little in between checks. I sprayed lines as best I could (hard to get at) and saw no obvious leaks. I've since installed an onboard compressor which has an air gauge in the dash which always shows current pressure. I've noticed about a 1lb per day loss when looking at same time of day at similar temps. Before I start getting overly involved in trouble shooting, I thought I'd ask if others have this issue. thx
Check the valve stem and be sure it's tight. I was losing about the same amount when I first got the RT and the stem had almost a full turn before it got tight. No excessive lose since.
